Wireless aggregation link
fluoro
Community Member
i'm try to connect 2 site with 3 pair of wireles bridge 1310 cisco.
cisco presales-support told me that is possible to do it using 2 catalyst 2950 switch and etherchannel configuration.
I've try to do it but something don't works fine.
Someone can Help me?
it's REALLY possible to do it !!!
ssoberlik
Level 9
Level 9
From your question I understand that you are having trouble configuring a Wireless bridge for point to point connection between 2 sites. You should find the following document useful which explains the configuration of all the features on a wireless bridge.
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_book09186a00804ebd50.html
