Wireless AirOS Global AP Syslog Level configuration command 7.4.121.0
Rolf Fuchser
Hello
I have a controller 5508 running on version 7.4.121.0. With the command "show ap config global" I can check the global AP syslog config:
AP global system logging host.................... 0.0.0.0
AP global system logging level................... informational
Default the syslog host ip is 0.0.0.0. With the command ">config ap syslog host global x.x.x.x" I can configure the IP of the syslog server.
Question:
How can I configure the global syslog level?
I searched in the command reference but there is no specific command to set the global AP syslog level.
Rolf
Rasika Nayanajith
Hi Rolf,
Here is the command you required
config ap logging syslog level <syslog_level> all
This post also should give you an idea how to configure syslog in different WLC platforms & how to analyze them using splunk
http://mrncciew.com/2014/09/19/wlc-syslog-analysis/
Pls mark the thread as "answered" if this is you looking for.
Rasika
