Wireless and QoS
j-morgenstern
Community Member
Hello everybody,
Does the Cisco Aironet AP support QoS ´(traffic priorization) for VoIP over Wireless?
pavelchjen
Community Member
I work with Lucent (ORINOCO) Wireless AP and routers.
Lucent AP does not support QoS. But I'm shure thet
If AP support Qos then i think it will work only if IP packet will go throught different interfaces, it will not work between two nodes which connected for example to the same wireless interface.
mmellet
Level 7
Level 7
The 350’s will have new firmware available soon that can identify QoS for voice traffic.
James Strong
Level 2
Level 2
The Aironet APs have a feature called SVP. Thi sis Spectralink Voice Prioritization. Basically, it reserves 1M of bandwidth for Spectralink phones when detected by the AP. This is not a configurable feature. If it detects Spectralink, it turns on. Otherwise, it is not enabled.
