Wireless authentication and ACS v3.2
mguzman4158
Hello there,
I have a question for ACS v3.2 - Does anyone know if ACS has to keep the session between ACS and Windows Database open for wireless users authentications? A little history on the problem: I have a wireless LAN using ACS v3.2 and on ACS I have defined a Windows Database to be used for unknown users (which are the 99% of wireless users) A lot of users are lossing connectivity and are being prompted to re-authenticate every so often. I'm trying to troubleshoot this issue. Thank you very much for your help in advance....
Stephen Rodriguez
Questions arise here. But to first answer your question, I do not believe that the link remains open. I think the ACS does an LDAP call to the AD, and once it gets the pass/fail, it closes that session.
What type of client NIC is being used?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks for the answered. To answer your question, the majority of users are using the Dell Wireless 1470 Mini-PCI Card
Manufacturer: Broadcom
Do you know if there is a known issue with this card?
Thxs!
