Wireless Authentication
piasterloo
Community Member
Folks ,
Our WAPs are set up on the Management VLAN 50, while the wireless users obtain their IP addresses from VLAN 80. Authentication is managed through a RADIUS server. Is it essential to enable inter-VLAN communication between VLAN 50 and VLAN 80 for successful authentication?
Please advise and thanks
5 Replies 5
michalc1
Which VLAN is the RADIUS server on?
If VLAN 50 - no need for interVLAN
If other than VLAN50 - yes for interVLAN need.
There is also an option for alternate MGMT interface if needed.
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
ww^
Meraki Community All-Star
No
You only need connectivity between the management ip and the radius
piasterloo
Community Member
radius server is not on prem...its hosted in the DC
DHAnderson
Level 5
Level 5
We have most of our clients using RADIUS for WiFi Authentication. The access points are on a management VLAN and the clients are on a different VLAN. No inter-VLAN traffic is allowed, and authentication works fine.
Dave Anderson
BlakeRichardson
This documentation has a great image showing how the process works.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_with_WPA2-Enterprise
So as long as your client can access the AP and the AP itself can access the Radius server you are all good.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
