05-27-2015 04:01 PM - edited 07-05-2021 03:18 AM
I have 2 APs in a mesh configuration WITHOUT an WLC. If a wireless client connects with the root AP all vlan traffic is passed. If a wireless client connect to a non-root AP on the native vlan 244 traffic is passed but no other vlan traffic is passed. Can someone with with getting all vlan thru the back-haul? I can manage the non-root ap on the native vlan.
05-27-2015 07:29 PM
if it is wireless bridge, you should set it "Root Bridge" and "Non-Root Bridge" roles with "wireless clients" keyword on respective AP's radio interfaces. See below (do not worry about EAP configuration, just initial part of config)
http://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
If you want to use Root AP as simple Access Point, then you have another option where you can configure far end AP as WGB. See below
http://mrncciew.com/2013/06/16/ios-ap-wgb-with-multiple-vlan/
Rasika
*** Pls rate all useful responses ***
05-30-2015 12:04 PM
thank you for your answer, but the design calls for 802.11a backhaul. you are using 802.11g for backhaul and clients. We need to use 802.11a to bachual all vlans.
05-30-2015 01:53 PM
if you use Radio1 interface (instead of Radio 0) then it should be 802.11a. You can use given configuration as reference and modify as you want.
Rasika
06-01-2015 06:02 AM
configs are attached. thanks
06-01-2015 06:03 AM
Configs are attached in first post.
