Wireless Bar Code Scanner
travis-dennis_2
Level 11
Level 11
Does anyone know of a wireles bar code scanner that will work with the AP1200s? I would like to link back over the wireless and instantly update a database.
tepatel
Many companys make wireless bar code scanners. Symbol Technologies have some good ones.
some good links for that
http://www.barcoding.com/barcode_scanners.shtml
http://www.pointofsaleinc.com/barcode-scanners.htm
davealfred
Community Member
We use Symbo 1846 devices. If needed they have the ability for a pistol grip also. We dont do much scanning but work great for our purpose
What kind of security are you using in Symbol to communicate with the 1200? WEP?
blue.modal
Level 6
Level 6
A Socket bar code CF card in a Toshiba e740 would be a cheap, simple solution.
Matthew Wheeler
Chief Wireless Architect
Blue Modal, Inc
www.bluemodal.com
