Wireless bridge as a trunk
I have a switch network running VLANs, and I need to extend this into a building that I can't physically get a cable to. I have two 1300 series bridges that I want to use to create a bridge between two switches in either building.
I need multiple VLANs to pass over the bridge.
Looking at the documentation the only examples I can find involve creating subinterfaces on the bridge ethernet port and setting each subinterface to its own VLAN and SSID.
Is there a way to get the devices to act as a bridge carrying multiple VLANs over a single SSID?
I don't want the bridges to act as Access Points - only bridges.
Cheers,
Ben
6 Replies 6
youmansk235
The 1410 bridge will do it. We are doing it right now. You have to setup sub interfaces on the radio but they do not need multiple ssid's. Try setting up one ssid on the 1300. Then under the radio and ethernet interfaces setup your sub interfaces. Under the radio interface setup your vlan encryption. The 1410 installation document has more details. I would assume that the 1300 will work the same.
Thanks youmansk - I will give it a try.
Cheers,
Ben
abrahamj
The wireless bridge is logically made up of two components: a transceiver and a bridge. The transceiver is a radio that will forward traffic to the next bridge; it doesn't care about VLANS. The management interface of the bridge should be on a separate IP addressing scheme, a /29 VLAN say, that looks like a P2P connection to the L3 gear it touches. If you are going L3 to L2 switch, keep the bridges on the vlan supporting the management interface of the switch--the vlans defined on the L3 gear will come through intact.
Abrahami,
The management interface BVI when dealing with sub-interfaces has to be on the native VLAN. I have made the management VLAN of the L2 switches the native VLAN and given the bridges an IP on that VLAN. Is this secure?
Secondly, I don't understand how to configure the FastEthernet port on the bridge to connect to the L2 switch. The switch must be a trunk in order to support multiple VLANs.
I can't find a way to configure the fastethernet on the bridge as a trunk without using multiple sub interfaces - so I don't understand the relationship between the radio and fastethernet sub interfaces.
Should i not be defining sub interfaces on the radio? Do I just map all fastethernet sub interfaces to a single SSID?
Below is a sample (working config) taken from a 1200 series.
dot11 ssid my-ssid
vlan 1
authentication open
infrastructure-ssid
power inline negotiation injector 001d.e692.b808
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
load-interval 30
shutdown
encryption key 1 size 128bit 7 F31439656A9323F25A0AB8F0B728 transmit-key
encryption mode wep mandatory
ssid my-ssid
parent 1 001d.7126.7680
station-role non-root bridge
mobile station scan 2462
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid my-ssid
antenna transmit right
antenna receive right
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 36.0 48.0 54.0
interface Dot11Radio1.1
encapsulation dot1Q 1 native
no ip route-cache
no snmp trap link-status
bridge-group 1
interface Dot11Radio1.145
encapsulation dot1Q 145
no ip route-cache
bridge-group 145
bridge-group 145 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.145
no ip route-cache
bridge-group 145
interface BVI1
ip address 10.30.55.35 255.255.248.0
no ip route-cache
ip default-gateway 10.30.55
Hopefully this helps.
Just what I was after - thank you!
