Wireless bridge between 57 Miles ?
admin_2
Level 3
Level 3
We need to connect two points with a wireless Bridge. One Point is on Bahamas and the other in Miami (57 Miles).
Use: Data / VOIP
We appreciate any recommendations to do this.
stsalina
57 miles over a highly reflective path is just not a good idea. Too much height needed for clearance and multipath will kill you even if you can afford the structure.
thisisshanky
Level 11
Level 11
This idea looks almost impossible. The maximum you can go with just two antennas is 25 miles. You could probably insert a repeater site but then I am not sure if this is an option in your case. Probably it might be a good idea to look for satellite or even microwave (this usually impose licensing issues.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
"The maximum you can go with just two antennas is 25 miles." Wrong Wrong Wrong
You need to use a 5.8 system, proxim, trango, redline, just to name a few have solutions. Trango will cost about 3k and go 40 miles with 7-8 megs. I have a trango at 34 miles, works great but it takes a good amount of time to setup at that distance.
