wireless bridge configuration
I hope that you are doing good.
I want to configure a Cisco isr 829 as bridge router (i want to  connect it in ssid that is configured by other access point(cisco 1800), and the client that connect in wired ports with isr 829 can connect in internet).Can you please help me?
Hi ,
Thank you so much for your reply.
For me i have lightweight access points that will be the roots.
How i can configure them by WLC?
Thank you.
We can make a network mesh between two access points with differents reference (air-1532 with isr 829).
Thank you
If you want to configure as work group bridge in Unified enviounment (with WLC and LAP )then follow this guide:
https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/100254-wgb-config.html
here is my posts about it:
https://rscciew.wordpress.com/2014/08/15/wgb-with-multiple-vlan-in-uwns/
Dont forget to rate helpful posts
