Wireless Bridge design question.
yong1794
Level 3
Level 3
I like to design one fixed root-bridge and shiftable non-root bridge.
The root bridge have Omni antenna and non-root bridge also have omni antenna. but important issue is non-root bridge is installed in the bus. bus is moving around in root-bridge's omini antenna coverage.
I like to know this design is available?
and second question is roaming issue.
over 100km/h moving client is able to roamming without signal loss between access points?
derwin
Level 10
Level 10
This is a pretty standard sort of design, from a toplogolgy point of view it does not matter the non root is in the bus
From a roaming point of view it gets a lot more complex.
At 100Klm/hr dopler shift *may* affect your signal quality.
You will also need the 'fast roaming' feature in the latest IOS version. I do not believe this has been included in the latest VxWorks version so this may cause you an issue.
High speed application have been done in the past but there is a number of challenges, your account team will be able to help you through these.
This is not a standard application so I strongly recommend that you work with your Cisco account team on this.
