Wireless Bridge Options
johnsyoung86
Community Member
I noticed that most of the Cisco Bridge products are now End of Life.  Is the current way to make a wireless bride to use an AP and setting it up as a bridge?  What product options do you suggest?  I just need to create a wireless bridge between our corp. office and a warehouse about 1/2 mile away to extend internet connection.  Buildings have line of sight.
2 Accepted Solutions
George Stefanick
Cisco recently released 1532 and 1572 radios. I shot the 1532 over a mile without issue just make sure you have line of sight.
sobhardw
1500 series AccessPoint. They are Mesh APs and used for bridging.
Point-to-Multipoint Wireless Bridging
Point-to-Point Wireless Bridging
Please follow the below Link : http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/design/guide/MeshAP.html
5 Replies 5
George Stefanick
You can use 1500 series AccessPoint. They are Mesh APs and used for bridging. They are much better then the 1300 and 1400 series bridges.
Thanks and regards,
Manas Pratap Singh
mohanak
The Cisco Aironet 1300 Series is a flexible, feature-rich outdoor 802.11g access point or bridge platform that provides high-speed, cost-effective wireless connectivity in the 2.4 GHz band between multiple fixed or mobile networks and clients. Designed specifically for harsh outdoor environments, the Cisco Aironet 1300 Series provides industry-leading performance with 100 milliwatts of transmit power and outstanding receive sensitivity, installation tools to assist in bridge placement, and a choice of integrated or connectorized SKUs. Data rates of up to 54 Mbps can be enabled for point-to-point links up to 1.5 miles in length, with throughput in excess of 22 Mbps.
But 1300 Series is EOL, please check the document for the replacement product with the similar features
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/end_of_life_notice_c51-711894.html
Moin Ilyas
Level 8
Level 8
Cisco Aironet 1530 Series:
Multiple operational modes, including access point, mesh, point-to-point, point-to-multipoint bridge, and workgroup bridge (WGB)
http://www.cisco.com/c/en/us/products/wireless/aironet-1530-series/index.html
sobhardw
