Wireless Bridge problem
johnnys
Level 2
Level 2
Goodday,
I have a 2 Aironet BR2040E working fine over 18km.
I'm upgrading to the Cisco BR350 , using the existing antennas.Which is 23dbi Grid antennas, with 10m low loss cable between antenna and bridge.
The Cisco bridges do not associate.
The cisco bridges however do work over a short distance, but not over 18km.
One is setup as root and the other as a nonroot.
The SSIDs are the same.
I have tried the different data rates and still not working.
On the old aironet bridges, the km needed to be specified.
Do I need to specify the km on the Cisco Bridges?
Any suggestions ?
regds
Yes you have the configure the km on the Bridge:
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_configuration_guide_chapter09186a008007f77f.html#97015
Configure it under: Setup /Root Radio Advanced Page
regards Bernhard
Thanks, Its working, one more question.
I have configured it for 5.5Mbps,
Where can I view the data rates that its setup for.
regds
Johnny
