Wireless bridge problems!
mrunal_47
Level 4
Level 4
Hi all,
I have a wireless bridge between two buildings with 54 Mbps link. However theres around 90% packet loss between the two sites. What would be the best way to take care of packet loss.Any wireless experts..?
Saurabh
paul.pink
Did you do a site survey to ensure there was not a lot of interference. You could be using a congested channel.
msalhi123
Community Member
can you check if there are a lot of interference.
what is the distance between two buildings.
what type of equipement.
the number of ports between the accespoint and your backbone.
