Wireless Bridge Question.
tei.kevin
Community Member
Is this possible?
AP1242AG(50mW Bridge Mode with 6dBi Patch Antenna)---(0.5mile)---BR1410(250mW Bridge with 6dBi Patch Antenna). Bandwidth should be over 10Mbps.
I think AP1242AG maximum power is low(50mW).
SO, AP1242AG's signal is not reach to BR1410 antenna. right?
Not applicable
You should be able to establish a Point to Point connectivity with Wireless Bridges 1200 series and 1400 provided the 1200 AP is configured as a Bridge. Power can always be adjusted to suit the environment and throughput requirements.
