wireless bridge with 2602 and 1262
rschwart
I have been tring to build a bridge with a 1262 on one end a 2602 on the other and not having any luck connecting. The 2602 replaced a damaged 1262. I only use the A radio for the bridge. Any suggestions on the config?
Sandeep Choudhary
please check these configs:
https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68087-bridges-pt-to-pt.html
Hope it helps.
Dont forget to rate helpful posts
Scott Fella
You should be able to use your old configuration, there might be some differences depending on the code you were running, but it should work.
-Scott
Pls attach two AP configurations to check
Rasika
