Wireless bridge
Wes Schochet
Level 7
Level 7
Hi all-
I am looking for a wireless bridge - to plug in a wired device and access the wireless network.  I would prefer a device that does EAP-TLS.  We have been using APs in workgroup-bridge mode, but I am hoping to reduce the complexity and price a little bit in this set up.  Does anyone ave a device that they are happy with?
Wes
Scott Fella
Wes,
Can’t you find a wireless NIC that goes into the device instead of trying to find a bridge?
-Scott
Unfortunately not - this is an older piece of radiology equipment - very proprietary!
Well I will be honest. I don’t know any external bridge that can do EAP-TLS. Maybe do a quick internet search and if you find one, test it out. Seems like that would be an issue down the road if the unit hangs and needs a reboot.
-Scott
