Wireless Canon Printer & AirPrint failing with WLC 7.0
MMstre
Level 3
Level 3
Recently i converted a customer's APs to LWAP and installed a 2504 WLC. Everything came up and is acting good, but the printer is no longer printing.  It can neither be discovered using windows networking, nor bonjour.  It worked until LWAPP conversion
It is an AirPrint device, a Canon mx892.
Trying to print using an IP port fails, AirPrint fails, and sharing it through the attached Mac also fails.
I dont know enough about printers or AirPrint to effectively troubleshoot.  The customer opened a case with Canon, who says its a network issue.
I cannot get it configured on the wire, apparently setting up a printer isnt as easy as it used to be.
Any help would be greatly appreciated.
Mike
Leo Laohoo
Would be nice if you can load 7.4.100.0 firmware.
Wireless LAN Apple Bonjour Deployment Guide
Leo Laohoo
