Wireless CD won't work
f1_2_max
Community Member
when i put the CD in nothing appears and my wireless network is locked with a network key. my model number for my router is WRT54GS its a wireless-G Broadband router with speedbooster Lynkys. is there any way i can run the progam from the website? my LAN works fine but need wireless for xbox live
beabrams
you need to check on linksys or call them...... this is a Cisco forum for only Cisco enterprise products...
also in most cases if you open a web browser to 192.168.1.1 and use admin admin as the username and password you can configure the wireless and router that way.
