Wireless Clean Air Oper Status ERROR
bimbrah99
Community Member
We have installed a number of Cisco Wireless 3502-07 in China and i can not get the Clean Air Oper status to change to UP. At the meoment i have ERROR. I have have tried to disable and enable the the Clean Admin Status from the Access Point 802.11b/g/n and then select the AP and change configuration.
Does anyone know who to resolve this ?
Erwin Salazar
Hi Balbir,
What controller platform and software version are you currently running?
What is the full part number for the AP?(ie. AIR-CAP3502I-A-K9)
Are there any relevant Traplogs for the ERROR state?  You can view the traplogs under Monitor > Most Recent Traps or grab it from the CLI via "show traplog"
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
Saravanan Lakshmanan
#Can you try to enable from cli.
#Also confirm whether cleanair works or not while its showing disabled.
#Check the AP crash log for AP crashes.
#Are all APs affected, do you've different country/region 3500 APs that's not seeing this issue.
