03-23-2010 02:52 AM - edited 07-03-2021 06:38 PM
hi. this is kim
i have some questions!!! please help
my customer use wireless network (controller based).
WLC 4404(4.2.130) + LAP(1131) + WPA1(TKIP) + Radius(ACS4.1)+HREAP
some client disconnect frequently, so we update client wireless driver, and change channel & power ,WLC RRM fix
so we change LAP to Autonomous AP,
all fine.. why?
i dont understand....why client disconnect?
please help!!!!
Solved! Go to Solution.
03-24-2010 08:18 PM
Kim,
Are all the ap's H-REAP and when troubleshooting, is the issue in a specific area. When you changed the AP's to Autonomous, were you still authenticating back to radius?
03-24-2010 09:43 PM
KIM:
Many problems are derives from customers, VISTA, cause many problems, and as for XP, must have all the patches,
03-24-2010 08:18 PM
Kim,
03-24-2010 09:43 PM
KIM:
03-29-2010 05:19 PM
sorry!! i'm very busy...^^
our all Client driver update, AP connect Radius(ACS)
all fine..
03-29-2010 08:33 PM
ok. I understand your problem, I spend the same a few months ago with the same infrastructure, raise a case with Cisco, which told us that the problems are the type derives by network design, as ap, have a limit, in my case, had 20 for the model 1130, as probedor I observe, that the problem was derived from customers, points out that the ap, the only thing it does is radiate the signal, but the client does is the one who initiates the negotiation.
As recommendation.
Check the number of customers each AP supports.
If possible perform a site survey, the controller Check how many customers are associar to each AP, it is possible that more than enough capacity.
For now is all I can think of.
Greetings.
03-29-2010 09:59 PM
thank you... your reply....
AP is enough.....and Client Driver all Update
I think that auto-AP NO RRM fuction.. but LAP RRM fuction enable
Channel Interference may give rise to Client Roaming..although Channel & Power is fix
I set-up more less tight Performance profile on Controller (Cisco recommand : Controller very tight)
I attach channel analyze report
result although Performance profile change more less tight on LAP environment
I think that controller base wireless inconsistence on heavy Channel Interference environment
thank you..!! please reply
