Wireless client reassociation
rasmus.elmholt
Level 7
Level 7
I have some troubles with one of my clients on my wireless networks.
The session timeout on my WLC is 30min. per default and the clients gets disconnected every 30 min as expected. But this one client takes about 1-2 minutes before i reconnects.
Is there any reason for this or is it a client problem?
Feb 21 09:30:35.623	*apfReceiveTask	Client session has timed out
Feb 21 09:30:35.623	*apfReceiveTask	Client expiration timer code set for 10 seconds. The reason: Client was marked for deletion, and it was on associated, power save or blacklist state. Other message would provide reason for delete
Feb 21 09:30:45.623	*apfReceiveTask	Client disassociation event has occured. Possible reasons may be due to AP Radio Reset usually due to channel change or wlan was manually disabled or Client unable to get valid DHCP IP for WLAN using DHCP required
Feb 21 09:30:45.624	*apfReceiveTask	Client has been deauthenticated
Feb 21 09:30:45.624	*apfReceiveTask	Client session has timed out
Feb 21 09:30:45.624	*apfReceiveTask	Client expiration timer code set for 10 seconds. The reason: Client has timedout during authentication at local controller, it is marked as idle, and deleted after timer expires. Possible client bouncing between Aps during authentication
Connection attempt #1
Feb 21 09:32:06.432	*apfMsConnTask_4	Client made new Association to AP/BSSID BSSID 18:8b:45:XX:XX:28 AP AP_NAME
Feb 21 09:32:06.433	*apfMsConnTask_4	The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Feb 21 09:32:06.434	*apfMsConnTask_4	The Reassociation Request from the client comes with 0 PMKID
Feb 21 09:32:06.434	*apfMsConnTask_4	Client is entering the 802.1x or PSK Authentication state
Feb 21 09:32:06.434	*apfMsConnTask_4	Client has successfully cleared AP association phase
Feb 21 09:32:06.434	*apfMsConnTask_4	Client is entering PSK Dot1x or WEP authentication phase
Feb 21 09:32:06.434	*apfMsConnTask_4	Client expiration timer code set for 1800 seconds. The reason: Client is scheduled for session timeout deletion (wlan with webauth)
Feb 21 09:32:06.434	*apfMsConnTask_4	WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Feb 21 09:32:06.441	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Sending M1
Feb 21 09:32:06.446	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Received M2
Feb 21 09:32:06.447	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Sending M3
Feb 21 09:32:06.451	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Received M4
Feb 21 09:32:06.452	*Dot1x_NW_MsgTask_7	Client has completed PSK Dot1x or WEP authentication phase
Feb 21 09:32:06.452	*Dot1x_NW_MsgTask_7	Client has entered DHCP Required state
Feb 21 09:32:06.505	*DHCP Socket Task	Received DHCP request from client
Feb 21 09:32:06.505	*DHCP Socket Task	Sending DHCP Request to DHCP Server 10.127.104.1 through gateway 10.127.104.254 requesting 10.127.104.37 on VLAN 104
Feb 21 09:32:06.506	*DHCP Socket Task	Sending DHCP Request to DHCP Server 10.127.104.1 through gateway 10.127.104.254 requesting 10.127.104.37 on VLAN received op BOOTREPLY (2) (len 310,vlan 104, port 13, encap 0xec00, xid 0x8ad5b19d)
Feb 21 09:32:06.507	*DHCP Socket Task	Client has entered RUN state
Feb 21 09:32:06.508	*DHCP Socket Task	Received DHCP ACK, assigning IP Address 10.127.104.37
Feb 21 09:32:06.508	*DHCP Socket Task	Received DHCP ACK from DHCP server
Feb 21 10:02:06.301	*apfReceiveTask	Client session has timed out
Feb 21 10:02:06.301	*apfReceiveTask	Client expiration timer code set for 10 seconds. The reason: Client was marked for deletion, and it was on associated, power save or blacklist state. Other message would provide reason for delete
Feb 21 10:02:16.301	*apfReceiveTask	Client disassociation event has occured. Possible reasons may be due to AP Radio Reset usually due to channel change or wlan was manually disabled or Client unable to get valid DHCP IP for WLAN using DHCP required
Feb 21 10:02:16.301	*apfReceiveTask	Client has been deauthenticated
Feb 21 10:02:16.301	*apfReceiveTask	Client session has timed out
Feb 21 10:02:16.301	*apfReceiveTask	Client expiration timer code set for 10 seconds. The reason: Client has timedout during authentication at local controller, it is marked as idle, and deleted after timer expires. Possible client bouncing between Aps during authentication
Connection attempt #2
Feb 21 10:03:36.777	*apfMsConnTask_4	Client made new Association to AP/BSSID BSSID 18:8b:45:XX:XX:28 AP AP_NAME
Feb 21 10:03:36.778	*apfMsConnTask_4	The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Feb 21 10:03:36.778	*apfMsConnTask_4	The Reassociation Request from the client comes with 0 PMKID
Feb 21 10:03:36.779	*apfMsConnTask_4	Client is entering the 802.1x or PSK Authentication state
Feb 21 10:03:36.779	*apfMsConnTask_4	Client has successfully cleared AP association phase
Feb 21 10:03:36.779	*apfMsConnTask_4	Client is entering PSK Dot1x or WEP authentication phase
Feb 21 10:03:36.779	*apfMsConnTask_4	Client expiration timer code set for 1800 seconds. The reason: Client is scheduled for session timeout deletion (wlan with webauth)
Feb 21 10:03:36.779	*apfMsConnTask_4	WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Feb 21 10:03:36.787	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Sending M1
Feb 21 10:03:36.792	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Received M2
Feb 21 10:03:36.793	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Sending M3
Feb 21 10:03:36.797	*Dot1x_NW_MsgTask_7	4-Way PTK Handshake, Received M4
Feb 21 10:03:36.798	*Dot1x_NW_MsgTask_7	Client has completed PSK Dot1x or WEP authentication phase
Feb 21 10:03:36.798	*Dot1x_NW_MsgTask_7	Client has entered DHCP Required state
Feb 21 10:03:36.874	*DHCP Socket Task	Received DHCP request from client
Feb 21 10:03:36.874	*DHCP Socket Task	Sending DHCP Request to DHCP Server 10.127.104.1 through gateway 10.127.104.254 requesting 10.127.104.37 on VLAN 104
Scott Fella
If it’s one device that has this issue then it’s the device. I personally disable session timers or increase that to a higher value.
-Scott
All the other devices seems to reconnect within 1-2 seconds.
I was thinking about changing the session timer to 4/8 hours, do you have any commends on if this is a good or a bad idea?
That is fine. If it was a guest SSID that is using a portal page, then I would set it higher. If it’s WPA2, for example, setting that to 4/8 is a good start. You need to also look if the re-association happens when the device comes out of sleep or hibernate because that might be just a device issue.
-Scott
