Wireless client static ip address
ibrkic001
Frequent Visitor
Frequent Visitor
is there a enabled "HREAP Local Switching: and enabled option "Learn Client ip address" on WLC can be a problem for static ip addresses on client?
we have problem with wireless connection for Android devices
Point is that we must have static IP addresses on Android devices in order to monitor that devices.
On one area when we have WLC with software version 8.5.135.0 everything works fine, but when we try all this
on area where is WLC with software version 7.0.252.0 , and enabled HREAP , after one period android loses wi-fi connection, and can not obtain again connection for that static IP. We must again switch on DHCP , and then works fine.
best regards
Rasika Nayanajith
Quiet possible it is due to feature differences between these two code releases
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/201007-AireOS-feature-list-per-release.html#
What is the issue you facing when the client set to DHCP?
Rasika
When we set  client to DHCP, then works fine, with occasional signal loss, and after that client returns on the network, but with settings with static IP address client can not return on network, we must back settings to DHCP.
