Wireless Client Whitelist
Vijay2918
Hi Team,
In the Meraki dashboard, we can whitelist 3000 wireless clients. Is it for the entire network or for the specific SSID?
What will happen if we whitelist more than 3000?
Where do we see the whitelisted client count details in the dashboard?
If we whitelist one of the device's MAC, how many days will it exist in the dashboard? If we can't connect the whitelisted device to the wireless network for more than a month, will it exist, or can we connect the device after 50 days from the day of whitelisting?
If the whitelisted working device gets inactive for 3 months, will it work after 3 months?
Some of the wireless clients frequently disconnect from the network. How can we mitigate that?
Is there any way to see all the client's individual connectivity time on a single page with the graphical representation for the specific SSID?
aleabrahao
Meraki Community All-Star
It's by network
Just filtering the clients to which it is applied, there is no counter.
On the clients page. https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Client_Details_Page_Overview
Take a look at the cloud data retetion policies
https://documentation.meraki.com/General_Administration/Privacy_and_Security/Cloud_Data_Retention_Policies
Yes
You need to be more specific, in this case I suggest you open a support case.
On client details. https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Clients_Usage_Page_Overview#Client_Details
For each of your questions you can read the documentation or open a support case.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Hi Alemabrahao,
Thank you for your response.
I got the information from your reply, and I tried to implement it. I found that we can filter and find the whitelisted device count for a maximum of one month from the client usage page.
I would like to know the exact number of whitelisted devices.
To know more about that, I am going to open a support case, as you suggest.
GreenMan
It seems to me that you might be trying to use a feature for a requirement for which it was not designed. You might be better to outline what you are trying to achieve and seeing if the hive mind can come up with a more appropriate solution..?
Hi Greenman ,
Yes, you are right. I think I am trying to get the details from the client usage page, which is not designed.
I would like to get the graphical usage details of each device that is connected to the SSID in a single file.
