Wireless clients can't get DHCP address from router behind Aironet 1100
paulsonger2
We want our wireless clients to get their IP address assigned by the router on the network, not the AP.
We tried configuring the 1100 with a static IP address in the proper subnet, as well as setting it as DHCP so it would get its own address from the router. Both of these configurations work as far as the 1100 being seen on the network. However, wireless clients never get an IP address. The 1100 seems to not want to pass these DHCP requests through to the DHCP server on the router.
How can this be resolved?
Richard Atkin
Level 4
Level 4
An 1100 will let DHCP pass to clients if everything is configured properly. Please post a Show Run from your AP, Switch & Router so we can take a look...
RA
Two SSID and client can not receve ip from DHCP.
If I make VLAN (SSID) native, all OK!
How make work two SSID?
OK. Here it is.
By the way, if I configure the wireless client with a proper static IP address, it will ping the 1100 but not beyond it.
Chelan6#show run
Building configuration...
Current configuration : 1420 bytes
version 12.3
no service pad
service password-encryption
hostname Chelan6
no logging console
enable secret xxx
ip subnet-zero
no aaa new-model
dot11 ssid CHELAN
vlan 1
authentication open
guest-mode
username Administrator privilege 15 password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid CHELAN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Chelan6#
I guess this can be disregarded now.
After power-cycling everything, including the Catalyst switch that is feeding the 1100's, everything is working as it should.
Apparently, some settings on either the AP or the switch don't take effect until after a power-cycle. I suspect the packets were being dropped because of a VLAN setting mismatch.
