Wireless clients cannot get ip address
evarner
Level 2
Level 2
I have 7 WLANs configured all work fine but the latest. The 7th WLAN I configured will not let clients get an IP address. I can plug a wire into the port with the same VLAN configured on the port and I get an IP address but wireless clients connected to an AP on that port cannot get an IP adddress. Any suggestions would be appreciated.
tfraij
where is the DHCP server configured?
- do all other 6 WLAN's work fine with the same DHCP server.
- do you have any H-REAP VLAN mapping , or AP groups configured?
they will override the WLAN-interface configuration.
Kind regards
Talal
please rate answers that you find useful , and mark as answered - when it is 🙂 - so others can find it easily
Router is doing DHCP. I do have AP groups configured so I will look at the configs for those to see if I find an issue. Will keep you posted. Thanks
chucktranhpb
Level 2
Level 2
Do the switch ports the APs are plugged into allow the VLAN for WLAN7 through?
