11-18-2015 09:57 AM - edited 07-05-2021 04:16 AM
Good afternoon everyone!
I'm going through some tasks and I'm not quite sure of the best approach. Was looking for some recommendations and/or pointers in the right direction. All of your responses would be much appreciated.
NOTE: All APs do meet requirements to fulfill the desired results.
The current setup is that of:
- 2x 5500 WLC (HA setup) running 7.6.120.0
- 8 WLANs
- 100 APs (Local/Monitor Mode)
- APs are currently registered and connected to the Primary 5500 WLC
Looking to have the desired end results:
1. Consolidating the 8 WLANs down to 3 WLANs
2. Converting the APs from Local/Monitor Mode to FlexConnect mode
3. Migrating the APs from the 5500 WLC to a HA Pair of Flex7500 WLCs running 7.6.130.0
Where is the best place to start with the above?
What is the recommended approach to complete each of the tasks?
Solved! Go to Solution.
11-18-2015 10:22 AM
I would like to understand reasoning behind Local mode to FlexConnect change. Is this mainly branch AP deployment ? How many sites and how many APs per site ?
Have you already got 7510 ? If not I would consider different platforms (5520 or even vWLC with upcoming 8.2.x code)
I would suggest 8.0.121.0 code as AP will not reboot while you convert to Flex in 8.x code. So you will get some time save with that code.
First I would consolidate the WLAN while keeping the AP in local mode.
Then work it out vlan/subnet (if doing Flex Local Switching) and do the preparation for FlexConnect migration.
Rasika
11-18-2015 10:22 AM
Rasika
11-18-2015 11:04 AM
Rasika-
Thanks for the prompt response, I will response to your question with details shortly!
