Wireless Control Center PAK
I installed Wireless Control System on a virtual 32bit Red Hat machine.  Now I need the PAK to license it. Along with the software CD, I was given the following four license packs:
Cisco One Mgmt Prime Infrastructure LMS 4.2 50 Device
Cisco One Mgmt Prime Infrastructure 2.x 50 Device
Cisco 50 AP CMX License
Cisco MSE License
Does anyone know which of the above is the PAK for the WCS?
Ric Beeching
Level 11
Level 11
Hi Stephen,
Cisco Wireless Control System was replaced with Cisco Prime Infrastructure (CPI) approximately 3 years ago. You will need to download and install the OVA within ESXi as it is not available as a Red Hat / Windows Server install like WCS was.
http://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/tsd-products-support-general-information.html
Please rate helpful / correct posts
Ric Beeching
Level 11
Level 11
Hi Stephen,
Thank you.
To be honest I was wondering about the software I was given.  It seems a little -- well -- out of date.
