Wireless Controller 2100
tahirs001
Level 2
Level 2
I have deployed a Cisco wireless environment at one of our sites.
The problem is that we are rolling out new motorola handhelds using windows 6.1 are not authenticating with the ACS. I have copied the same config as it was with the exsisting  wireless that was installed. the laptops use the same certificate as the motorola hanheld and can authenticate without any issues.
When I look at the ACS for logs I get the following error;
EAP-TLS or PEAP authentication failed during SSL handshake
Is there some kind of configuration that I have missed out, or something that the controller is is not passing it through to the ACS??
0 Replies 0
