Wireless controller 2500 - guest vlan
mmasenya
Frequent Visitor
Frequent Visitor
Hi all
I need help on configuring guest vlan on the 2500 controller and get it working. I have attached some pictures (screen shots) of how i configured it but i am struggling to get it working. The diagram (high-level) is at the bottom of the attached file.
Here is what i have done
> Two VLANs running
> Configured WLAN corporate Users (SSID-DV8).
> This is working 100% with no issues at all
Guest network
> I have created a guest network called (Baeti)but can't get it to work.
> This is VLAN 25 in the controller assigned to port 2 on the controller.
> Users do get ip addresses from the dhcp residing in the controller.
> Traffic from this vlan should go straight to internet via the router (192.168.0.1/24) but this is not happening.
> Where am i missing it?
Hi Sandeeb
I went for option 2 as per your suggestion and I got it right. All i did was to trunk the port and everything worked.
Thanx very much for your help.
Sandeep Choudhary
There are two ways:
1. You can use just port1 and configure the switchport as trunk , allowing multiple vlans.
means Guest and Internal user will go via same port 1.
2. If you are using 2 ports on WLC for two vlans then make sure while creating the Dynamic interfaces you tag port1 with management vlan and tag port 2 with the other vlan.
Case1-
Just use Port 1 -- Switch port to be configured as trunk and allow vlan xx(Internal) and 25(Guest)
Case 2-
Use Port 1 and 2-
Switchport mapped with port1 (management) to be tagged with management (Vlan xx - internal)
Switchport mapped with port 2 to be tagged with vlan 25(Guest)
On the WLC Management interface to be mapped with port1 and Dynamic interface for vlan 25 to be mapped with port 2.
Dont forget to rate helpful posts
Hi Sandeeb
I am glad it worked.
