Wireless Controller 5520 connection issue
riyadhit
Community Member
We have cisco 5520 wireless controller connect to 88 Aps, Suddenly in the morning some of the clients got connected and some of them get connected but says no internet.
connected clients are both 2.4 and 5GHZ clients.
Please advice
5 Replies 5
Mark Elsen
 - Enable client debugging for the particular Mac's on the controller ; you can have the debugs analyzed with :
                       https://cway.cisco.com/tools/WirelessDebugAnalyzer/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Sandeep Choudhary
How is the WLAN configured ?
is any specific type of clients are having issue or ?
paste the output of these commands:
sh wlan <id>
debug client <mac address of the client>
Dont forget to rate helpful posts
Anjana A
Level 4
Level 4
whether the internet unable access is related to a specific wlan or all the wlan.
please check whether users got correct ip address and gateway ip address.
Please check whether users able to ping default gateway.
try pinging 8.8.8.8 from the core switch a source as user vlan/ also from wlc try pinging 8.8.8.8
Anjana
Scott Fella
"No Internet" means that DNS is not working on those subnets.  Maybe check your NAT.... Just verify if the device gets authenticated and or get an ip address from the correct subnet.  That usually eliminates wireless issues and points to something upstream.
-Scott
Leo Laohoo
"some of the clients" -- Are these clients getting valid IP addresses or not?
