Wireless Controller DHCP Issue
ErickBCCNA
Level 3
Level 3
I want to upgrade to Code level 7.0, but I want to be sure that bug ID CSCth68708 has been resolved or is not an issue at that code level.
Thanks.
George Stefanick
Erick,
You would need to request the "TAC special" release from TAC. Its code 7.0.98.4 .... This will have the bug fix you are looking for ...
https://supportforums.cisco.com/message/3276562#3276562
George Stefanick
Erick,
Yeah.  That's what I was afraid of.  Thanks for the prompt response.
i understand a new 7.x release will be out in the next few weeks.
I can confirm, but my local representative just said soon.  If it's that soon, I will just go ahead and wait for the new release.  Thank you very much for your time.
