Wireless controller PN
faris.y.b
Community Member
I saw in the datasheet that the controller 5520-50 supports 50 AP ?
but up to it says it supports up to 1500.
Kindly explain
Hilda Arteaga
Hi [email protected]
The Cisco 5520 Wireless Controller supports 50 access points.
However, due to licensing it has flexibility to add additional access points (up to 1500 access points) as business needs grow. In other words, you can add more AP according to you business needs and throughout licenses.
This you will have to check out with your Cisco provider/representative.
I hope this helps!
