Wireless controller
Khalidi2007
Community Member
Can i managed Access point 3110 and 1602 using 2504 controller with software 7.4.x?
Sandeep Choudhary
1310 ??? last support version is 7.0.X.
1602 need 7.4.100.0 version on wlc.(It will work )
Check this matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
abwahid
Level 9
Level 9
2504 Controller with software 7.4.x do support 1602
but do not support 3110 OR if you mean1310.
Moin Ilyas
Level 8
Level 8
Adding to abwahid, please find the attached pdf file listing all the compatible APs.
