wireless controller
mohdilyasali
Visitor
Below mentioned log are getting in wireless controller 2100 s , SSID are broadcasting but problem is that when i connecting SSID limit access ..plz help to solve .. adv thank.
*Nov 01 16:13:43.195: %SYSTEM-3-PASSWD_STORE_INTEGRITY_FAILED: passwd_store.c:470 Cannot retrieve secret from store -- integrity check failed.
*Nov 01 16:09:05.225: %DHCP-3-ADDR_NOTIN_POOL: pools.c:80 Error: Ip Address 172.16.217.15 is not in pool (10.1.109.15-> 10.1.109.254)
*Nov 01 16:08:20.851: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:08:13.909: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:08:07.655: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:08:03.675: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:08:02.765: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:08:02.764: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 01 16:07:50.845: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'cliWebInitParms.cfg'
*Nov 01 16:07:50.812: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'rrcEngineInitParms.cfg'
*Nov 01 16:07:50.812: %CNFGR-3-INV_COMP_ID: cnfgr.c:2115 Invalid Component Id : Unrecognized (80) in cfgConfiguratorInit.
*Nov 01 16:07:50.785: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'rfidInitParms.cfg'
*Nov 01 16:07:50.769: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'dhcpParms.cfg'
*Nov 01 16:07:50.547: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'rrmInitParms.cfg'
*Nov 01 16:07:50.507: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'apfInitParms.cfg'
*Nov 01 16:07:50.401: %MM-3-MEMBER_ADD_FAILED: mm_dir.c:903 Could not add Mobility Member. Reason: IP already assigned, Member-Count:1,MAC: 00:00:00:00:00:00, IP: 0.0.0.0
*Nov 01 16:07:50.196: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'mmInitParms.cfg'
*Nov 01 16:07:48.030: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'aaaapiInitParms.cfg'
*Nov 01 16:07:48.027: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'pemInitParms.cfg'
*Nov 01 16:07:48.020: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'dot1xInitParms.cfg'
*Nov 01 16:07:48.007: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'capwapInitParms.cfg'
*Nov 01 16:07:47.983: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'spamInitParms.cfg'
*Nov 01 16:07:47.983: %SSHPM-3-FREAD_FAILED: sshpmlscscep.c:1395 Error reading file /mnt/application/lscca_pem.crt
*Nov 01 16:07:42.941: %SYSTEM-3-FILE_READ_FAIL: nvstore.c:422 Failed to read configuration file 'sshpmInitParms.cfg'
*Nov 01 16:07:42.940: %CNFGR-3-INV_COMP_ID: cnfgr.c:2115 Invalid Component Id : Unrecognized (36) in cfgConfiguratorInit.
Nov 01 16:07:41.252: [ERROR] phy.c 155: link on port 1 change to up
Nov 01 16:07:41.245: [ERROR] phy.c 155: link on port 0 change to up
Also upgrade your WLC to 7.0.250.0 image.
Rasika
**** Pls rate all useful responses ****
5 Replies 5
Rasika Nayanajith
What is the software version running on your 2100 ? Also did you try to reboot & see
Rasika
I already tried that restart device and below mentioned version running.
Primary Boot Image............................... 6.0.199.4 (active)
Backup Boot Image................................ 6.0.199.4
and configure of device of please find the out attached file.
Now again am getting an other error as below mentoined.still user getting ip address but there are not able access anything.. plz help me to solved this issue. you can contant on my skype id :babababa5222 ,
mgs log :
13:27:39.751: %LWAPP-3-WLAN_ERR2: spam_lrad.c:20904 Unable to find WLAN 1 to be deleted; AP f0:25:72:12:93:70
*Nov 04 13:27:39.750: %LWAPP-3-WLAN_ERR2: spam_lrad.c:21261 Unable to find WLAN 1 to be deleted; AP f0:25:72:12:93:70
*Nov 04 13:27:39.749: %LWAPP-3-WLAN_ERR2: spam_lrad.c:20904 Unable to find WLAN 1 to be deleted; AP 08:17:35:02:64:30
*Nov 04 13:27:39.749: %LWAPP-3-WLAN_ERR2: spam_lrad.c:21261 Unable to find WLAN 1 to be deleted; AP 08:17:35:02:64:30
*Nov 04 13:27:39.747: %LWAPP-3-WLAN_ERR2: spam_lrad.c:20904 Unable to find WLAN 1 to be deleted; AP 08:17:35:02:0b:10
*Nov 04 13:27:39.747: %LWAPP-3-WLAN_ERR2: spam_lrad.c:21261 Unable to find WLAN 1 to be deleted; AP 08:17:35:02:0b:10
*Nov 02 08:13:01.153: %RRM-3-RRM_LOGMSG: rrmChanUtils.c:292 RRM LOG: Airewave Director: Could not find valid channel lists for 802.11bg
*Nov 02 08:10:14.930: %CAPWAP-3-INVALID_STATE_EVENT: capwap_ac_sm.c:5697 Invalid AP event (7) and state (4) combination
Create an SSID with open authentication.  Can you join that SSID?  If you can't then it's not a "wireless" issue with your WLC.
If you can, then start ramping up the security and encryption on the WLC until you break things.
Ok, I will try that above mentioned and will update soon .. thank for reply my mgs.
Thank You
Mohammad Ilyas Ali
Rasika
