Wireless Controller
nematosama
Dears,
We purchased Cisco Virtual Controller, and we don't know from where we can download the VM.
Any guide,
Kind Regards!
Mark Elsen
 - FYI : https://software.cisco.com/download/home/286322605/type/282046477/release/Bengaluru-17.6.4
    If you refer to older (aireos based) : https://software.cisco.com/download/home/284464214/type/280926587/release/8.5.182.0
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
nematosama
Dear Marce,
What about Cisco Software Support SWSS, How can I activate it.
Kind Regard!
Have you spoken to the vendor whom you purchased this from?  I would believe they can help you through the support, license, etc.  The guides on Cisco.com are very helpful, you just have to find the one specific to what you have purchased.  The vendor should be able to walk you through the support, because they might have to do something on their end also.
-Scott
