Wireless country codes
pkilkenny
Frequent Visitor
Frequent Visitor
                  there are no matching country codes in WLC for Azerbaijan so what country code can be selected for this country? Geographically it borders with Russia and former soviet states but cannot find specific information regarding regulations around wifi compliance for Azerbaijan.  would using a code from the correct regulatory domain in Europe cause any problems?  would it be similar to Kazakhstan, that has a country code on the WLC?
Chris Illsley
Level 8
Level 8
Looking at this document it has Azerbaijan as in the EMEA (Europe, Middle East and Asia), which I suppose shouldn't be too surprising:
http://www.net130.com/attestation/ccip/jc/Cisco%20Aironet%20Wireless%20LAN%20Fundamentals%20AWLF%203.1.pdf
Make sure your Regulatory Domain is -E and that looks fine.
Chris
pkilkenny
Frequent Visitor
Frequent Visitor
so which country code should be selected for a wireless implementation in Azerbaijan?
I'm suspecting this is "-E" but the best bet is to create a Cisco TAC Case.   Two reasons why:
1.  You want to get this in writing; and
2.  So next firmware (or engineering) release will have Azerbaijan in the list.
Abha Jha
Code from the correct regulatory domain in Europe will not cause any problem.
There is no country code available for Azerbaijan (AZ) as of
now.
You may get more info from below link:-
http://www.cisco.com/en/US/docs/wireless/access_point/channels/lwapp/reference/guide/lwap_
chp.pdf
