wireless coverage 1811
rygar1234
Level 2
Level 2
I need to configure the router to give me the best coverage possible what is the best approach to do that? 802.11b speed is more than enough but my router has only A and G.
Thank you
irisrios
Level 11
Level 11
This can be done using the command speed range under dot11 interface confiugration mode. Refer to URL http://cisco.com/en/US/docs/routers/access/1800/wireless/configuration/guide/s37rf.html#wp1134649 for more information.
