The "common-functions" widget cannot be found.
05-23-2003 07:45 AM - edited 07-04-2021 08:43 AM
Does anyone know of a free utility for 'real-time' monitoring of Wireless signal. I am looking for something to load on my notebook, that I can walk around with and display in real time a coverage map of the RF coverage area from the bridge.. I am using the Aironet 350, running 12.0.0 software...
Thanks .. Len
05-25-2003 06:44 PM
If you are using a Cisco client card then the lastest ACU install package has a utility called ACM this will put an icon on your toll bar to give signal strength and quality.
For a site survery you are better off using the site survey tool in the ACU
05-30-2003 04:42 AM
Now we just need to be able to connect a GPS and have the data logged with the location and stengths.
-Mike
