Wireless Design Validation
latintrpt
Level 5
Level 5
I wanted some opinions to see if my wireless AP layout for this particular is correct or not.
AP's: Cisco 3502i's
Deployment: 802.11a/n
Site Dimensions: 323.04 ft x 521.48 ft.
Spacing of AP's: anywhere from 30 - 50 ft depending on walls'.
Tool used: Airmagnet Planner.
Site: typical clinic, dry wall
I circled the area where I believe I am correct.
Attached is the drawing
Thank You
Leo Laohoo
I do hope you've got a WLC because the APs deployed is very, very dense and I think it's a waste of AP resources.
What kind of walls do you have?  Did you "scale" the map before you do a wireless site survey?  What power are the APs on?  What data rates did you configure the APs to use?
They are dry wall and yes I scaled the map correctly.
In the survey I set the AP's at 25 mW on 802.11an.  802.11g will be disabled so for 802.11a, I will go off the 7925G deployment guide for data rates.
I have update the ap placement.  Apparently the scale was off a bit.  The requirements have changed for this site, they just want data on 802.11n using 5GHz.
Am I on the right path on AP placement?
