wireless design
r.kukreja
Level 5
Level 5
is outdoor series 1552 and indoor series 1131 both work together with wlc4402 . if not kindly suggest outdoor and indoor technology which can creat indoor mesh and outdoor mesh and indoor and outdoor meash also be connected
Leo Laohoo
Depends on the firmware you are using but the 1130 can support MESH firmware.
Main thing to consider:  HOW MANY radios does your 1131 have?  If only one, then it's no use.
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_mesh.html#wp1452057
