Wireless DHCP problem
I have a problem
We have cisco ap 500 series, it was lightweight, but we migrate it to standalone, now, the scheme is simple.
We have a router 2811 and dhcp created on it, also we have f0/0.30 virtual interface with ip of 10.10.30.1
On switch one interface (trunk) goes to router f0/0 interface, and one interface (access) goes to ap
On AP we have BVI interface with 10.10.30.10, and default route to 10.10.30.1
So when we connecting to our SSID, it connect but doestn receive DHCP, and takes APIPA address, please explain why ap doesnt assign ip to clients
Also ap config.txt here
Thank you
Kamran,
Yes, sorry, that was unclear. Make your switchport interface the trunk. You do this on the switch:
(config-if)switch# switchport trunk encap dot1q
(config-if)switch# switchport mode trunk
Justin
12 Replies 12
Justin Kurynny
Level 9
Level 9
Kamran,
Can you ping from the router to the AP? From the AP to the router?
Assuming your 2811's fa0/0.30 is encapsulation dot1q 30, is your switchport that your AP is connected to set to switchport access vlan 30?
Make sure VLAN 30 exists on your switch ((config)#vlan 30). You can have it assigned on a switchport, but if it doesn't exist in the VLAN database, no traffic will pass on VLAN 30.
Justin
Yep, Ping is going from ap to router and vice versa, fa0/0.30 also has encapsulation dot1q30
Ap connect to switchport with switchport access vlan 30
Vlan 30 in database
I dont understand why ap doesnt broadcast dhcp
Kamran,
Can you post the AP config? I think you tried to post it in your first message, but it didn't come through.
Justin
Kamran,
Also, the router config? Remove passwords, keys, etc. Thanks.
Justin
Here is AP configs:
show run
*Mar  1 00:25:26.377: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
Current configuration : 1607 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$cFC2$NdW0rVFAwPMOIuKhfk6G1/
aaa new-model
aaa session-id common
dot11 vlan-name VLAN30 vlan 30
dot11 ssid VLAB
   vlan 30
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid VLAB
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 195
bridge-group 195 subscriber-loop-control
bridge-group 195 block-unknown-source
no bridge-group 195 source-learning
ap#
ap#
ap#show run
version 12.4
no service pad
hostname ap
aaa new-model
dot11 ssid VLAB
   vlan 30
   authentication open
   guest-mode
username Cisco
bridge irb
no ip address
no ip route-cache
ssid VLAB
station-role root
bridge-group 1
no ip route-cache
bridge-group 195
no bridge-group 195 unicast-flooding
bridge-group 195 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.30
no ip route-cache
bridge-group 195
interface BVI1
ip address 10.10.30.10 255.255.255.0
no ip route-cache
ip default-gateway 10.10.30.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
end
and Router config:
version 12.4
hostname HQRTR
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
no aaa new-model
memory-size iomem 10
clock timezone AZT 4
network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.30.1 10.10.30.10
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp pool HQPHONES
   network 10.10.30.0 255.255.255.0
   default-router 10.10.30.1
   option 150 ip 10.1.200.101 10.1.200.102
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
application
service aa flash:app-b-acd-aa-2.1.2.3.tcl
  paramspace english index 1
  param number-of-hunt-grps 1
  param menu-timeout 6
  param handoff-string aa
  param dial-by-extension-option 5
  param max-time-vm-retry 2
  param aa-pilot 5555
  param max-extension-length 4
  paramspace english location flash:
  param voice-mail 6000
  param service-name queue
service queue flash:app-b-acd-2.1.2.3.tcl
  param aa-hunt3 2222
  param queue-len 10
archive
log config
  hidekeys
controller E1 0/0/0
ds0-group 1 timeslots 1-5 type fxo-loop-start
controller E1 0/0/1
interface Loopback0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.1.200.1 255.255.255.0
ip nat inside
ip virtual-reassembly
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.200.1
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
interface FastEthernet0/0.30
ip address 10.10.30.1 255.255.255.0
interface FastEthernet0/0.39
interface FastEthernet0/1
ip address 172.31.7.21 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/1/0
no ip address
encapsulation frame-relay IETF
no fair-queue
frame-relay lmi-type ansi
interface Serial0/1/0.1 point-to-point
ip address 10.10.111.1 255.255.255.0
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 201
interface Serial0/1/0.2 point-to-point
ip address 10.10.112.1 255.255.255.0
ip ospf mtu-ignore
frame-relay interface-dlci 202
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 10.1.200.1 0.0.0.0 area 0
network 10.10.20.1 0.0.0.0 area 0
network 10.10.30.1 0.0.0.0 area 0
network 10.10.111.1 0.0.0.0 area 0
network 10.10.112.1 0.0.0.0 area 0
network 192.168.1.1 0.0.0.0 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.31.7.1
ip http server
ip nat inside source list NAT interface FastEthernet0/1 overload
ip access-list standard NAT
permit 10.0.0.0 0.255.255.255
control-plane
voice-port 0/0/0:1
output attenuation 0
ccm-manager redundant-host 10.1.200.102
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.200.101
mgcp
mgcp call-agent 10.1.200.102 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 1004 voip
service aa
destination-pattern 5555
session target ipv4:192.168.1.1
incoming called-number 5555
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2222 voip
destination-pattern 2222
session target ipv4:10.1.200.101
codec g711ulaw
no vad
dial-peer voice 50 pots
port 0/0/0:1
Kamran,
The problem is that your AP is set up for trunking. The client associates, sends a DHCP request, and the AP tags it with 802.1q tag 30 before sending to the switch. The switchport is set up for access and doesn't understand tags, so the packet is dropped.
You need to change your switchport for your AP to look like this:
interface
description AP
You will need to tag your BVI interface with VLAN 30 and put it in bridge-group 195 if you want to reach its management IP (30.10).
Alternatively, you can strip out all the VLAN tagging and subinterfaces on your AP and just do everything on the default VLAN. In this setup you can leave your switchport as an access port in VLAN 30.
Justin
Justin,
But on AP interface there is no command to change switchport encapsulation or make trunk,
or you mean Switchport ?
Kamran,
Justin
Yep, it worked, thank you Justin
Also it the first time i see config like
Cisco classic wireless scheme when ap is in access mode by default with switchport
thank you
Kamran,
When a switchport is in trunking mode, the switchport access vlan command has no effect. You can remove it safely with the no form of that command.
Justin
Justin, if it has no effect, why when i remove access vlan, wireless ap stops broadcasting dhcp?
Kamran,
The switchport access vlan command is only relevant when the switchport is set to switchport mode access. In access mode, the configured VLAN acts like a “native” vlan—all untagged traffic coming into the port is classified on the switch as part of that vlan-id. When you change the switchport mode to trunking (switchpport mode trunk), the access vlan statement is ignored and the port starts using the 802.1q extensions for frame classification. By default, the native vlan is 1 (this is the vlan that untagged traffic coming or going is placed in) and tagged traffic is both accepted incoming and passed outgoing.
At least that’s my understanding. ☺
Because you are using dot1q encapsulation on your AP, the AP is sending frames out with the vlan 30 tag and with your switchport in trunking mode, the traffic flows. Your BVI1 interface is essentially in the default vlan, which is why pings worked when you still had your switchport as an access port set for vlan 30.
Can you copy/paste the configuration for the switchport? Now you have me scratching my head..
Justin
