Wireless Differences between the US and Australia
nh6we
Level 2
Level 2
Can anyone tell me if there are any differences in ordering products (access points) for Australia?  Should I use difference part numbers other than what I would use for the US?  Also are there any differences in 2.4 or 5ghz channels?
Thanks for the help
Rasika Nayanajith
Regulatory domain for AU/NZ is "Z" . Therefore you need to select the part numbers specific to that regulatory domain.
eg AIR-CAP3702I-Z-K9
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1300-series/product_data_sheet0900aecd80537b6a.html
Rasika
**** Pls rate all useful responses ****
Moin Ilyas
Level 8
Level 8
Adding to Rasika,
So, I believe there won't be any difference in 2.4 or 5ghz channels for both the countries.
Source: http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob41dg/emob41dg-wrapper/ch3_WLAN.pdf
Please also refer to: http://www.cisco.com/c/en/us/td/docs/routers/access/3200/software/wireless/3200WirelessConfigGuide/RadioChannelFrequencies.pdf
Hope that helps.
