wireless disconnect
wyfy-2015
Level 3
Level 3
I have an issue like wireless disconnect and connect   time to time .
I beleive that timeout = session time out which is set on the controller .
controller 5760
It could be possible ?
How to start troubleshooting
6 Replies 6
ayush902921
Community Member
What is the wireless device you are using? How many mac-address does it support.
Its laptops both windows and mac .
Are you facing same issue with you mobile..? If yes then its related to you Wifi Modem..
What modem you are talking about 🙂
Your laptop is connecting to some wifi device / Modem / Router. I want to know about that.
