Wireless DNS problem
JonChing
Visitor
Hi Everyone,
After I have setup the Switch, WLC, Server, under the wireless I could only use Ip address to access the servers but not with domain name. Under the Lan I could use both. Is there any setting which I need to setup with the WLC or something to do with DNS server or the client.
Hello
Not sure I understand, Are you saying from a wireless client you cannot resolve dns querys?
res
Paul
Kind Regards
Paul
Hi Paul,
Thanks for your reply, Yes under wireless client cannot resolve DNS querys?
WLCs should not be able to affect this
Open your user command prompt and give us the ff.(assuming windows user):
Can you show us an "ipconfig /all" of a wired user as you say that works
and an "ipconfig /all" of a wireless user that doesnt work
