Wireless Dynamic VLAN
awagih
Community Member
Hi everyone,
I have AP1200; also I am using a PEAP as an authentication protocol and ACS3.3 as AAA server. I have configured several VLANs on the AP (say for example VLAN 10, 20 and 30).
My question is, can I use the ACS to assign a dynamic VLAN per authenticated user credentials (Username/Password), as the method used in the dot1x found in the Catalyst switches? If, yes what is the required configurations to be done on both the AP and the ACS?
Thanks and best Regards
beth-martin
Level 10
Level 10
