Wireless External Antenna Access Point - Clarification
ciscokid7181
Level 2
Level 2
Dear Team ,
I would like to know, if i purchase Cisco 2702E ( that is with external antenna type) . Will it work without antennas , as we plan to purchase antennas later ?
Aaron
Leo Laohoo
Short answer is NO, it won't work.  Long answer is yes but by doing so can permanently "burn" the radios and void the warranty.
Don't risk it.  If there are no antennas, don't even put the AP(s) in the network.
mohanak
No it won't work.
Antennas are a key component of a Wi-Fi access point, and they have a big impact on network performance.
