Wireless Failed Connection
ricardorojas123
Level 7
Level 7
Hi I have a cisco wireless lan controller, and a WLAN configured with 802.1X, the users are registered sucessfull but if the station is disconnect and and tries again to connect to the WLAN this authentication is not complete, the computer must be restart to
reconnect again to the wlan with autenthication 802.1X.
Wireless Lan Controller version: 4.0
Wireless Client: Windows XP service pack 2
Scott Fella
Do you happen to have an IBM laptop. I had seen issues and it was due to certain drivers. Using the latest driver seemed to fix the issue.
-Scott
No, the wireless driver is Intel !!!!
I understand, but IBM might have the intel card. Try to download the latest manufacturer recommended driver for the intel card you have.
-Scott
