wireless flex-connect
Mike Vzz
Level 2
Level 2
hello networkers,
somebody know if si compatible mode operation flexconnect with wgb.
You can have some AP modes. Flexconnect and bridge are different modes and you need to choose between them. You can't have both.
 If you need a scenario like the one on the topology then you need to go for mesh APs.
-If I helped you somehow, please, rate it as useful.-
