Wireless Guest and Broadcast
gnijs
Level 4
Level 4
All,
The design guide specifies the following limitation: "As designed, 4400 series controllers do not forward IP subnet broadcasts from the wired network to wireless clients across the EoIP guest tunnel."
Does this mean that i cannot initiate a connection from a wired PC (or the default gateway) to a wireless PC (even after is has authenticated ?) because arp
would be unable to resolve or find the mac address of the wireless PC (ARP REQUEST broadcast will fail because it is not broadcast to the remote wireless client, if i read this limitation correctly)
mchin345
Level 6
Level 6
The feature works for clients on the same controller at all times...meaning no inter-controller roaming.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn421760.html#wp234085
